hi Infragistics Inc.:
I tried to upgrade my project(my project is build in VB 2010 old edition)
But, I have the following Issue:
Log text:
02:12:43: Analyzing wsMANAGER2004.vbproj...02:12:43: The project has references that need to be updated.02:12:47: The specified file/path D:\wsMANAGER\SFC\Packaging %28Bottle&Blister%29\Packaging.resx could not be found.02:14:20: Could not locate registry entry Software\Microsoft\.NETCore\v4.5\AssemblyFoldersEx where we look for installed products.02:14:20: Could not locate registry entry Software\Microsoft\.NETCore\v4.5\AssemblyFoldersEx where we look for installed products.02:14:20: Could not locate registry entry Software\Microsoft\.NETCore\v4.5\AssemblyFoldersEx where we look for installed products.02:24:56: Could not locate registry entry Software\Microsoft\.NETCore\v4.5\AssemblyFoldersEx where we look for installed products.02:24:56: Could not locate registry entry Software\Microsoft\.NETCore\v4.5\AssemblyFoldersEx where we look for installed products.02:24:56: Could not locate registry entry Software\Microsoft\.NETCore\v4.5\AssemblyFoldersEx where we look for installed products.02:25:51: Could not locate registry entry Software\Microsoft\.NETCore\v4.5\AssemblyFoldersEx where we look for installed products.02:26:10: Gathering volume and assembly information.02:26:10: Could not locate registry entry Software\Microsoft\.NETCore\v4.5\AssemblyFoldersEx where we look for installed products.02:26:12: ProjectFile element: wsMANAGER2004.vbproj is being treated as a proj file.02:26:12: Analyzing wsMANAGER2004.vbproj...02:26:12: The project has references that need to be updated.02:26:16: The specified file/path D:\wsMANAGER\SFC\Packaging %28Bottle&Blister%29\Packaging.resx could not be found.02:26:28: Upgrading Solution wsMANAGER2004.sln02:26:28: Updating wsMANAGER2004.vbproj...02:26:28: D:\wsMANAGER\wsMANAGER2004.vbproj has been backed up.02:26:28: No matching assembly located in available assemblies Infragistics.Excel.v3.102:26:28: at Infragistics.VersionUtilitySupport.Core.Product.AssemblyXmlFile.ThrowExceptionWhenAssemblyCouldNotBeFound(String assemblyName, Boolean checkAdditionalMessage) at Infragistics.VersionUtilitySupport.Core.Product.AssemblyXmlFile.LocateNewAssembliesNodeforCurrentAssembly(String assemblyName) at Infragistics.VersionUtilitySupport.Core.File.Types.ProjectFile.Upgrade(String rootDirectory)
I reinstall Net.4.0, but the probles still
I appreciate any help.
The assembly "Infragistics.Excel" was renamed to "Infragistics.Documents.Excel". I would recommend manually replacing the "Infragistics.Excel.v3.1" assembly reference with a reference to "Infragistics4.Documents.Excel.v16.1", or the same assembly from the target version.
The default installation folder is "C:\Program Files (x86)\Infragistics\2016.1\Windows Forms\CLR4.0\Bin", where "2016.1" is your target version. You can find the assemblies in this folder.
Let me know if you have any further questions.
Elizabeth AlbertLocalization Engineer
