157
Display a (table)or a gridview in treeview
HI,
I have just joined the forum I got a trial version. I have to populate a treeview (WinForm)..where the parent node is laready filled by me through database but now the child nodes should display all the 4 columns whcih can be editable ....is it possible ..if yes how? Please replay as soon as possible ..because if its possible and I am able to do it then I have to buy this ...product
TeachSam
  • 28464
    Thanks for downloading our products and giving them a try. This is the WebForms treeview forum however, so if you need additional information you can try posting in this forum instead (the Winforms one):
    http://forums.infragistics.com/forums/103.aspx
    You can browse through the forums there and use our search as well, maybe you can reach an answer even before we respond, for example here:
    http://forums.infragistics.com/forums/p/3813/19565.aspx#19565
    and here in general (a search)
    http://forums.infragistics.com/search/SearchResults.aspx?q=columns+edit&s=103
    You can also browse through our documentation located here:
    http://help.infragistics.com
    Hope this helps!
