95
Popup window from currently edited grid row
Can anyone suggest how I could accomplish the following:  be able to invoke a pop-up window and have the results posted into the current grid row after the pop-up window is closed.
  • 2211
    Hello cd_mackenzie,
    I don't know what version of Infragistics you are using but if you have at least 8.1 you can use the new aikido webdialogwindow as a popup.  You can add a JavaScript listener for mouse move and capture the x and y positions of the mouse and show the dialog window at the mouse location.  The aspx page displayed in the webdialogwindow handles the update for the grid and has a button that has its OnClick attribute set to a JavaScript function.  This JavaScript function can reference a JavaScript function on the opening page by using the parent.thejavascriptfunction method.  In the JavaScript on the parent window you would simply cause a post back of the gird using:
    igtbl_doPostBack('TheGridID');
    Then hide the dialog window with:
    var dialog = $find('TheDialogWindowID');
    dialog.set_windowState($IG.DialogWindowState.Hidden);
    Hope it helps,
    Patrick
    update:
    Forgot to tell you to add a client side event for the mouse click or double click to show the dialog window.
