as I read some other guides have problems with webdatechooser and AJAX implementation.
I have sometimes the same problems, that webdatechooser works and in some other cases not works, but this i most time solved, when postback-property of webdatechooser is set to false.
So I made the experience, if I have no mix of postback within the AJAX-panel it works fine.
But now I need it like follows: I have a search-part in my web-Application which have
an infragistics-Combobox - for selecting customers
and two radio-Buttons:
- one for typing a number in a text-field
- the other for activate the timframe-webdatechooser
when I open the webapplication with timeframe-Button and the webdatechooser are shown; combobox and webdatechooser works most time fine.
After I changed to number-Search and the postback of number-Search hide webdatechooser; combobox doesn't work.
Also after comeing back to timeframe webdatechooser doesn't work. It's not possible to choose anything from one of the infragistics elements. Only typeing date is possible.
I need the postbacks of the radio-Button for refreshing the screen and coordinate the select statements.
Any idea??
Thanks for help
Hi Carl,
I think solving this problem is going to require a little more one on one support, which is why I'm going to recommend that you submit this incident through our online system (https://es.infragistics.com/support) where a support engineer can work with you to create a repro case, etc.
-Tony
