1935
Alignment of screen elements
I can't seem to figure out the rhyme or reason behind the X/Y values when trying to align objects.
Sometimes 0 means the top Z-order item is perfectly aligned with the lower Z-order item.
Other times -1 means the top Z-order item is perfectly aligned with the lower item
Can someone share the logic of what's going on with these X/Y values
