Hello Infragistics team,
I wanted to ask you whether there will be the support for iOS 8+ Safari prototype view. Right now, when we export the project (doesn't matter if it is on your or our server), open it in Safari and then save it to the Desktop - the problem starts to occur. The prototype slides "under" the upper status bar with time, battery and so on. At the same time there starts to be the black line at the bottom of the screen.
The problem is that buttons in the header of the prototype cannot be pressed, because of they are covered with system information. Usability testing in that case starts to be real problem.
Thank you very much
Lukas Tresnak
Hi Diego,
Sure, it is iPad Air 1 with iOS 8 on a landscape mode.
Best regards,
Lukas
Hi Lukas,
Can you tell me what device are you using to run the prototype (iphone 5/6/6+/ipad)? Is the prototype portrait or landscape?
Diego
Indigo Studio Team
