Hi
I tried placing a transparent PNG of iPhone on the wireframe in a top layer. The frame is also sort of working as a mask when the animations are coming in from outside the screen. The only problem - it interferes with the taps/clicks on the existing elements. Any ideas / workarounds for this?
S
Hi Andres,
Some of the ui elements are coming from outside the screen for the opening animation. It looks odd when these elements are visible above the iPhone frame. So moving the frame back is not an option.
I guess I can create invisible hit area above the frame instead.
Eagerly waiting for V2. Thanks for the great product.
Hi Sujith,
Yes, if the image is on the top layer it will get all the clicks even if it's transparent. What if you move it to the back?
BTW, you won't need the iPhone PNG in our 'full' V2 version.
Andres
