Hi!
I get the following error message during the installation:
It looks like you are missing a couple of things that Indigo needs. Use the buttons bellow to download and install them.
Get Silverlight 5
Cet .NET Framework 4.0
Silverlight and .net had been installed on my system (Win 7 x64). I've tried reinstalling both of the programms, but still get the same message.
How can I fix this problem?
The problem was solved when i start the installation using command shell as admin (unfortunately, context menu of msi don't have this option)
Thanx for help, Brian!
If we can get a log file of the installation, we may be able to determine why the installation isn't able to satisfy the prerequisites. To generate one, start up a command prompt as an administrator, go to the directory the MSI is in and use this command line:
msiexec /i IndigoStudio.msi /lvx* log.txt
Go through the normal steps you've gone through to reproduce the error, end the installation, and then we can look through the complete log file to examine for errors.
