20
Unable to select data endpoints from OpenAPI definition
I am trying to connect my api that is being hosted through azure app service. While I am capable of adding the source via a link to the remote json file definition when I go into the configure endpoints menu is where the trouble begins. I see the endpoints of the api all listed, I am unable to select any of them as they are all greyed out and uninteractable. There is no shown error nor have I seen any error in the adding data source workflow, so my question is - why can I not select any of the api endpoints? The version of swagger is also up to date as I tested with a local hosted api and was able to select endpoints. Is this an issue with a azure hosted api, or some configuration problem? No authorization is needed for the api and it clearly recognizes the schema of the api, so I'm a little confused.
