I'm working on the form application, I'm trying to change the font family, colour and size. And same as the input line/box.
But I am unable to change those items in the libraries.
Hello Hari,
what are the rest 7 items and typographies that you are mentioning? In the meantime while we investigate the issue, I want to remind you that you may open up Indigo-Styling, go to the typohraphy page and command select all the layers there to change their typeface altogether, or select the ones that you feel are off and adjust them one by one.
Stefan
HI,
Thank you for the link. Found it helpful.
But when I tried to change the typography using Theme plugin, I found that the font for "Body 2" and "Caption" was only updated. Rest of the 7 items weren't. (I did change the font in the theme plugin).
Is this a bug? If not, Please let me know how to solve this issue.
P.S: I am using the latest version of Sketch(version 53.2) and MAC BOOK PRO 15 - 2019 model.
Thanks for contacting us.
If you are using our UI kit at Sketch, you can edit UI element properties using our Theme plugin. Here you can find more information about it.
Please let us know if you need further information.
Best regards,
Claudia
Indigo Team
