While I tried to install Design Studio, it shows that Silverlight and .Net 4.0 is not installed. I have installed silverlight 5 (64 bit) and Visual studio 2010 and 2012 are already installed with .Net Framework 4.0 and 4.5 on my Windows 10 Pro Laptop.
I am puzzled. What to do.
Rumzi
Hi, Rumzi!
Thanks for contacting us.
Could you please try the following?
1. Open an administrator command prompt where the installer file is. 2. Run this command: msiexec /i "IndigoStudio.msi" /lvx* log.txt
This forces a re-install that may fix the problem. If it not, could you please send us the log.txt file to indigo [at] infragistics.com?
Thanks for your time.
Best regards,ClaudiaIndigo Studio Team
