590
Facing issue while applying initialSummaryDescriptions.
Hi
I want a small clarification on one of the use case related to IgrDataGrid (https://es.infragistics.com/products/ignite-ui-react/react/components/grids/data-grid/overview).
I have used IgrDataGrid, in that when I try to set initial summary description with the following code snippet.
const summary: IgrColumnSummaryDescription[] = [];
const summaryColumn= new IgrColumnSummaryDescription();
summaryColumn.field = 'TestColumn';
summaryColumn.displayName = 'Test Display Name';
summaryColumn.calculatorDisplayName = '';
summaryColumn.operand = DataSourceSummaryOperand.Sum;
summary.push(summaryColumn);
This is the code snippet I'm using , here I'm passing displayName = 'Test Display Name' and  calculatorDisplayName  as Empty string still I'm getting  result  TestColumn sum 555 , as  displayName is  'Test Display Name' and calculatorDisplayName   is Empty string so I'm expecting result like this Test Display Name 555
So, for this I need to know how can we achieve that , If there is any solution for this please suggest  as I need to implement this in my IgrDataGrid.
Hoping for a positive response.
Thanks!!!
