590
Facing issue while applying default grouping in IgrDataGrid.
Hi
I want a small clarification on one of the use case related to IgrDataGrid (https://es.infragistics.com/products/ignite-ui-react/react/components/grids/data-grid/overview).
I have used IgrDataGrid, in that I want to apply default grouping , so whenever we open the grid , default grouping should be there.
Case1: When we apply grouping manually then grouping bar is there ,  but as we wanted default grouping so we don't want the grouping bar.
Case2: If we apply default grouping with multiple columns then we wanted that it should be grouping inside grouping.
So, for this I need to know how can we achieve that , If there is any solution for this please suggest  as I need to implement this in my IgrDataGrid.
Hoping for a positive response.
Thanks!!!
  • 34810
    Hello Shubham,
    I have been investigating into the behaviors you are looking to achieve in this case, and I have some information for you. I will answer your cases in the order they were asked.
    Case 1: If you do not wish to have the grouping bar in the IgrDataGrid, you can set the isGroupByAreaVisible property of the grid to false.
    Case 2: To have a hierarchical grouping structure with multiple groups, you can set the groupHeaderDisplayMode property of the grid to “Split.”
