15
React Spreadsheet - drag and drop
I am testing the React Spreadsheet and have found a use case that I cannot get to work.
I wish to be able to click on different cells within the React Spreadsheet control & drag each of them outside of the control onto a separate control so that I can link the active cell (worksheet/row/column) with the external control data.
Is this possible? I cannot see a way of doing this without having a third control that can get the active cell data (via activeCellChanged) and then having to drag this control.
Thanks, Dan.
  • 29085
    Hello Daniel,
    Thank you for contacting Infragistics. The spreadsheet does not support any type of Drag Drop. You can submit a feature request on our github page here:
    https://github.com/IgniteUI/igniteui-react/issues/
    The selectionChanged event might make more sense if you are dragging multiple cells. You'll have to capture a mouse up on the "paste" control and then add items based on what was in that selection manually.
