115
igdatachart is not rendereing with changed value
I have an jquery application which receives the data from external source like mqtt,
onMessageArrived i.e, on change in data - datasource in igDataChart the graph is not updating with latest/new value added though the control is coming to igDataChart method
$("#Speed").igDataChart({
        //        remove: true,
                width : "100%",
                height : "400px",
                title : "Time vs Speed and speedlimit",
                horizontalZoomable : true,
                verticalZoomable : true,
                windowResponse : "immediate",
                overviewPlusDetailPaneVisibility : "visible",
                dataSource : speedJarray,
                axes : [ {
                    type : "categoryX",
                    title : "Time",
                    label : "entered"
                    type : "numericY",
                    minimumValue : 0,
                    title : "KMPH",
                series : [ {
                    title : "Speed",
                    type : "spline",
                    xAxis : "NameAxis",
                    yAxis : "SpeedAxis",
                    thickness: 3,
                    isTransitionInEnabled : true,
                    isHighlightingEnabled : true,
                    showTooltip : true,
                    valueMemberPath : "speedO",
                    transitionDuration: 500
                    title : "SpeedLimit",
                    type : "spline",
                    xAxis : "NameAxis",
                    thickness: 3,
                    showTooltip : true,
                    valueMemberPath : "speedlimitO",
            $("#Speed").igDataChart("flush");
this is how my code looks like, on adding json object to speedJarray Iam calling drawSpeed(), but only first time the graph is plotting but not from the second time
