I’m using Razor syntax to create my igCombos. In 13.2, I was able to use the following code to create a combo and select the initial item:
@(Html.Infragistics().ComboFor(x => Model.QueryAggregate)
.ID("QueryAggregate_" + Model.Id)
.TextKey("Text").ValueKey("Value")
.EnableClearButton(false)
.DataSource(EnumHlpr.GetEnumSelectList(typeof(GroupBy)))
.DataBind()
.Render()
This used to work well, and the combo selected the initial Model.QueryAggregate item. I am finding that in 15.1, there is no initial item selected. I am able to get around this by adding the following line:
.ComboInitialSelectedItems(x => x.Settings.Add(new ComboInitialSelectedItemsSettings() { Value = (int)Model.QueryAggregate }))
This seems a little redundant because this used to work fine without setting the ComboInitialSelectedItems. I would expect the igCombo control to work like it did in 13.2 and not be required to set ComboInitialSelectedItems when using ComboFor.
Paul
Okay, thanks for the update.
Thanks for using Infragistics controls!
We have changed the combo in 15.1 version. It's rewritten from the ground and there are a lot of improvements and changes. Here you can find the migration topic - http://www.igniteui.com/help/igcombo-migrating-to-the-new-combo
My suggestion is to use that approach you have listed.
