How can i use Infragistics 12.120121.2059 version with bootstrap 3.2. Please guide me step by step . Its urgent.in bootstrap i am using jquery 1.9.1.min.js file which is not supported by infragistics
Hello Dilip Tripathy,
If there are any additional questions regarding this matter, please let us know.
I'm afraid we don't support jquery 1.9.* in 12.1 versions. For more information you can take a look at this thread (http://es.infragistics.com/community/forums/t/78323.aspx). We start the support for jquery 1.9.* from 13.1 versions and this also applies for the newest version.
You can take a look how to update to the new versions (http://www.igniteui.com/help/manually-updating-previous-versions) should happen.
And of course if you need any further assistance or other questions on updating to the newest version, please don't hesitate to share them with us.
Hi DeyanK ,
I want to make my query more clear. Actually i am using MVC4 with infragistics and there i want to use Bootstrap. I don't know this is possible or not because Bootstrap uses 1.9.1min.js or higher and infragistics 12.120121.2059 version uses 1.6.2min.js. I want to know is it possible to work with above mentioned technique or i need to add bootstrap latest version to make it compatible with bootstrap . If i am using latest version is it required to change my old code?
Here's a sample which demonstrate the usage of bootstrap with IgniteUI controls. http://www.igniteui.com/themes/bootstrap-default
From the bootstrap theme generator you can use any bootstrap with IgniteUI. http://www.igniteui.com/bootstrap-theme-generator/default
And this is step by step guidance of the usage of the generator http://www.igniteui.com/bootstrap-theme-generator/Help
There are also topics on this http://www.igniteui.com/help/using-ignite-ui-with-bootstrap
