I use the angular ig-grid directive to create a bound datagrid.
<ig-grid id="mainCharacters-grid" data-source="commicBook.strip.MainCharacters" primary-key="Id" auto-generate-columns="false" width="100%"> <columns> <column key="Id" header-text="ID" width="65px" data-type="number"></column> <column key="Name" header-text="Last Name" width="800px" data-type="string"></column> <column key="Gender" header-text="Gender" width="100%" data-type="string"></column> </columns> <features> <feature name="Sorting"> </feature> <feature name="Filtering"> </feature> <feature name="Updating"> <column-settings> <column-setting column-key="Id"> <editor-options read-only="{{gridOptions.readOnlyValue}}"></editor-options> </column-setting> </column-settings> </feature> </features> </ig-grid>
I would like to set(change) the readonly on the first column based on a value in my controller. The change is triggered by button click.
<button ng-click="OnChangeReadOnlyClicked();" title="Change readonly">Change Readonly</button>
The clickevent changes the value, but the first column remains editable even though the $Scope.gridOptions.readOnlyValue is true.
The content of the controller:
(function () { 'use strict' app.controller('commicBookController', controller); function controller($scope, dataServices) { var readOnly = false; $scope.commicBook = getCommicBook(); $scope.gridOptions = { readOnlyValue: readOnly }; function getCommicBook() { dataServices.getCommicBook(1) .success(function (data) { $scope.commicBook = data; }) .error(function (error) { alert(error.message); }); } $scope.OnChangeReadOnlyClicked = function () { readOnly = !readOnly; $scope.gridOptions.readOnlyValue = readOnly; }; }})();
What am I missing to make the change of the value effective, so that the first column becomes readonly?
Hello Erik,
Your suggestion is good and I've created a new issue on GitHub to research whether it's possible to implement it with the current architecture.Let me know if you have further questions regarding this subject.
Best regards,Martin PavlovInfragistics, Inc.
Thank you for the answer. We will try to implement this solution.
Although it would be nice to have the posibility to change (some) grid options the angular way.
Kind regards,
Erik
Hello Eddy,
The grid custom Angular directive is processed only once at the time of the initialization and does not support Angular expression binding "{{}}" the way you use it. At runtime you should use the API provided by the control.
For example if you want to change the "Id" column to read-only at runtime you should use the following code:
$("#mainCharacters-grid").igGridUpdating("option", "columnSettings", [{columnKey: "Id", readOnly: true}])
Hope this helps,Martin PavlovInfragistics, Inc.
