335
IgGrid, WebAPI and AngularJS
Hello, I'm trying to implement a simple CRUD scenario with the IgniteUI, AngularJS and ASP.NET WebAPI
HTML:
<ig-grid id="grid1"data-source="data" primary-key="id" auto-generate-columns="false" auto-commit="true"
response-data-key="d.results.Results"
response-total-rec-count-key="d.results.Count">
<columns>
<column key="ID" header-text="ID" data-type="number" hidden="hidden"></column>
<column key="Projekt" header-text="Projekt" data-type="string"></column>
</columns>
<features>
 <feature name="Updating" columnkey="ID"></feature>
</features>
</ig-grid>
BLOCKED SCRIPT
var sampleApp = angular.module('sampleApp', ['igniteui-directives', 'ui.bootstrap']);
sampleApp.service('dataService', ['$http', '$q', function ($http, $q) {
'use strict';
this.getAll = function () {
    var deferred = $q.defer();
    $http.get("/api/timeentries").success(deferred.resolve).error(deferred.reject);
    return deferred.promise;
sampleApp.controller('timeCtrl', ['$scope', 'dataService', function ($scope, dataService) {
   dataService.getAll().then(function (data) {
          $scope.data = data;
   }, function (error) {
          $scope.error = error;
And an WebAPI Controller as an endpoint:
public IEnumerable<Object> Get()
  TestEntities context = new TestEntities();
  var res = from sa in context.TimeEntries
  select new { ID = sa.SA_ID, Projekt = sa.Projekt.PJ_Bezeichnung };
  return res.ToList();
My question is: How can I implement the update/create/delete functionaltiy?
I have seen different examples how this can be done with asp.net or angularjs in combination with the northwind database, but there is no example how the twoway databinding and updating/create/delete works with WebAPI and AngularJS in combination.
Can you help me? I would really like to use this combination for future Projects in my Company.
