Hello
I am trying to format a cell in iggrid. The cell value is of a double value and is formatted with (format: 'currency').
Here is what I see:
- When Amt is < 0 and
- When using this in grid { headerText: 'Amount' , key: 'Amt', dataType: 'number' , template: '{{if ${Amt} < 0}} print this {{else}} print that {{/if}}'}, format: 'currency' },
'print that' gets printed.
- When using this in grid { headerText: 'Amount' , key: 'Amt', dataType: 'number' , template: '{{if ${Amt} < 0}} print this {{else}} print that {{/if}}'} }, // (note the removal of "format: 'currency'")
'print this' gets printed.
I am assuming that when the template trying to resolve this it takes the 'formatted' value (in this case with $ sign and () if negative) and try to resolve it but it returns always false. Is there a way to fix this.
Herald
HI Martin
Its very disappointing. I am using your licensed version and hence expecting a response from you ASAP. i have some client deliverable which is getting delayed because i am not getting any response from Team.
It will be very help full you Response on this ASAP.
Hi Martin
Sorry i forgot to mentioned i don't want to loose datatype, I didn't want to loose currency(number) sorting and filtering
I am looking for very urgent quick help
i have columns applied currency format, is there any way to have one column with two decimal which is default but another column with three decimal and another with four decimal.
I understand that $.ig.regional.defaults i have to set min/max value for currency, suppose i set min to 0 and max to 9 and but how can we set dynamically column decimal value to according to my need for each column.
How can I achieve that.
I felt $.ig.formatter this can help me but didn't understand this function completely, since its not mentioned any documentation can you help me to understand this function.
I tried this but didn't worked $.ig.formatter(9332.44567889, "number", "currency",null,null,'0.00')
Your ASAP response will be very helpful for me.
Hello Herald,
I'm attaching a sample demonstrating how you can achieve this scenario.
Let me know if you have further questions regarding this subject.
Best regards,Martin PavlovInfragistics, Inc.
In my case I wanted t apply both formatting like turn for ex. 1.23 to $1.23 and apply a specific CSS style for ex. $1.23 for val > 0 and $1.23 for val <= 0.
