1490
set lable value
Hi, please refer to my attached png.    You can find lable values, such as :  0 , 250 , 500 ,750 ... 2500 .  That's because I set labelInterval=250.
But I have the requirement to set range's end value ,  the range property I defined is below :
ranges: [
{ name: "range1", brush: "rgba(142, 199, 8, 1)", startValue: "0", endValue: "500"},
{ name: "range2", brush: "rgba(235, 217, 11, 1)", startValue: "500", endValue: "900"},
{ name: "range3", brush: "rgba(62, 211, 205, 1)", startValue: "900", endValue: "1600"},
{ name: "range4", brush: "rgba(206, 109, 240, 1)", startValue: "1600", endValue: "2100"},
{ name: "range5", brush: "rgba(233, 52, 61, 1)", startValue: "2100", endValue: "2500" }
I just want to show numbers :  0 , 500 ,900 , 1600 ,2100 ,2500 .   not the numbers I set by labelInterval .
Do I make mysefy clearly?   Thanks in advance.
