Anyone have a functional example of a Tree using MVC Helper where you can set the icons?
I try several examples and options but nothing work, i need to set a relative path to the image of each node depending of her type....any ideas?
Hi Oliver,
Can you show an example of how you're trying to configure the img paths and also tell us where the images are located in your project?
Thanks in advance!
I have done some looking into this matter and have some follow up questions concerning this matter.
Have you tried passing in from the Model and using the imageUrlKey to bind to the data?
https://www.igniteui.com/help/api/2014.2/ui.igtree#options:bindings.imageUrlKey
What have you tried so far?
Please let me know if you have any questions concerning this matter.
