I have a grid with igGridSelection enabled and i am using the row selectors. The check boxes work fine, allowing a user to select multiple rows with ease. However, if they click outside of the check box, they will select that row and also lose any other rows selected. How can I disable the row selection when the user clicks anything that isn't the row selector checkbox?
Currently I am trying to stop it in the rowSelectionChanging event. The only problem here is that neither the evt or the ui variables exposes a difference based on where the user clicked, despite it being obvious that the tool is handling the two separately. In chrome, I can use event.currentTarget to tell the difference, but I do not have this option in Firefox 24 which my client is using. Also, the rowSelectorClicked event in the igGridRowSelectors api fires when someone clicks the row selector's cell, but not the selector itself. Any help would be greatly appreciated.
How can i get ID of selected checkbox
hi Vasya, on a similar related topic, is there a way for me to DYNAMICALLY select/deselect row or check/uncheck the checkbox if I know a row Index/ID ? Your help looking into this is greatly appreciated.
Trung
Hello Milind,
I am glad that you have been able to achieve your requirement.
Please feel free to contact me if you need any further assistance with this matter.
Vasya,
I actually came to this same conclusion this morning. I was able to implement the features exactly as I wanted. Thanks for your time and attention. I greatly appreciate it.
What I can suggest for achieving your requirement is handling rowSelectionChanging event. In this event the else clause(which means that the selection is not coming from a checkbox)could be handled. Right before the event is cancelled the row could be forced to enter edit mode. For example:
rowSelectionChanging: function (evt, ui) { if (isFiredFromCheckbox) { alert('Event fired from checkbox'); isFiredFromCheckbox = false; } else { //in this case selection is caused by regular selection and it is canceled by returning false $("#cbRowSelectors").igGridUpdating("startEdit", ui.row.id, 0); return false; } }
else {
return false;
I am attaching my modified sample for your reference.
Please let me know if you need any further assistance with this matter.
