Hello.
I'm using IgniteUI grid. Its datasource is a JSON object obtanied via AJAX. The grid is locally paged and filtered. I need to export the entire set of results (using filters applied but without mattering the paging).
I've seen Ingragistics Excel overview but it doesn't use the filter. Even if I could add filter parameters, I would have to get the data from the DB again, and I'd like to avoid that.
I've also seen Client Side Excel Library but I couldn't get it working. Also, I need to support IE9+, and that solution is not IE9 compatible. It could be make IE9 compatible posting the data to the server, and genereting the file to download from the server, however I also read that: "the client side excel export is still in CTP and therefore not recommended or supported to be used in production environment" in this post.
So, how can I do to export the grid? Maybe somehow serializing its information and posting it to the server?
Diego
Hello Tsanna.
I could resolve this, the problem was that I was calling a method from the igGrid API before initializing it. For some reason it didn't throw any error but then, when I tried to initialize the grid, it didnt work.
Thanks for your assistance.
Hi intecomp,
Did you manage to resolve your issue?
If I can provide you further help regarding this matter, feel free to contact me.
Tsanna
It was an specific issue from this scenario. Trying to extract a simple example I found the issue, I wasn't using the right parameters and everything messed up. Thanks.
I'm attaching the sample that I used to test this behavior. Please feel free to modify it and try to reproduce the issue on your side, then send it back to me. The sample is tested with v14.2 as well.
Waiting for your reply.
I mean that not even the headers. Absolutely nothing. In fact the <table> element I use to build the grid disappears. I'm using v14.2.20142. Maybe this could be a scenario issue.
