I'm having a bit of trouble with an igCombo element. I want the field to either be BLANK on entry to the page, or contain a "--Pick One--" (preferably semi greyed out, like the 'placeholder' in a text field.) nullText should work but doesn't; the page is loaded and the first list item is displayed.
The only way I can get it blank on initial display is to have TWO lines of code for it:
$("#ddlType").igCombo({ text:"" });
$("#ddlType").igCombo("option","text","");
Why do I need to have both of these to simply have nothing selected on a new page?
Hello CJ,Default igCombo behavior is exactly what you require. You could see an online basic sample illustrating this at:http://igniteui.com/combo/overviewIn order to have a text displayed when there is no selection made, I suggests using nullText option, like described here:http://help.infragistics.com/jQuery/2014.2/ui.igcombo#options:nullText
For example:$(function () {
var data = [ { "ID":1, "Name": "John Smith", "Age": 45 }, { "ID":2, "Name": "Mary Johnson", "Age": 32 }, { "ID":3, "Name": "Bob Ferguson", "Age": 27 } ]; $("#combo").igCombo({ dataSource: data, //JSON Array defined above valueKey: "ID", textKey: "Name", nullText : "--Pick One--" }); });
