345
dataSource.type()==="remoteUrl" is setting null
in my case if i try to bind grid using below mentioned datasource url
function GetDetailForInvoiceLanguage() {
LoadInvoiceLanguageListINGrid(null);
DestroyDependentGrid();
$("#PickList").addClass("modalMain").fadeIn("slow");
ParentGridFristRowSelection();
function LoadInvoiceLanguageListINGrid(datasource) {
var showInactiveColumn = GetInactiveCheckboxValue();
DestroyParentGrid();
$("#gridPickList").igGrid({
primaryKey: "InvoiceLanguageID",
autoGenerateColumns: false,
width: "500px",
height: parentGridHeight,
caption: $("#hdnGridCaptionText").val(),
renderCheckboxes: true,
aggregateTransactions: true,
responseDataKey: 'Records',
responseDataType: "jsonp",
requestError: ShowRequesterror,
updateUrl: '@Url.Content("~/PickList/SaveInvoiceLanguagePickList")',
columns: [
{ headerText: "Invoice Language ID", key: "InvoiceLanguageID", dataType: "number", width: "25px" },
{ headerText: "Inactive", key: "Inactive", dataType: "bool", width: "75px" },
{ headerText: "Surveyor", key: "SurveyorID", dataType: "string", hidden: true, formatter: formatSurveyorCombo, width: "25px" },
headerText: "Surveyor", key: "Surveyor", unbound: true, dataType: "string", width: "150px", formula: function (row, grid) {
return formatSurveyorCombo(row.SurveyorID);
{ headerText: "Company", key: "NominatingCompanyID", dataType: "string", hidden: true, formatter: formatCompanyCombo, width: "25px" },
headerText: "Company", key: "Company", unbound: true, dataType: "string", width: "150px", formula: function (row, grid) {
return formatCompanyCombo(row.NominatingCompanyID);
{ headerText: "Text", key: "Text", dataType: "string", width: "100px" },
dataSource: '@Url.Content("~/PickList/GetDetailForInvoiceLanguage")' + '?isChecked=' + $('#hdnIsInActiveChecked').val(), //datasource,
features: [
//enableVerticalRendering: false,
columnSettings: [
columnKey: 'InvoiceLanguageID',
allowHiding: true,
hidden: true
columnKey: 'Inactive',
allowHiding: true,
hidden: showInactiveColumn //true
style: "popover",
visibility: "overflow",
showDelay: 500,
hideDelay: 100
enableVerticalRendering: true,
reactOnContainerWidthChanges: true,
windowWidthToRenderVertically: null,
mode: "row",
multipleSelection: false,
touchDragSelect: false, // this is true by default
multipleCellSelectOnClick: false
type: "local"
type: "local",
mode: "simple",
dataFiltering: PickListGridDataFiltering
editMode: pickListGridEditMode,
enableAddRow: pickListGridEditMode == 'none' ? false : true,
enableDeleteRow: pickListGridEditMode == 'none' ? false : true,
columnSettings:
columnKey: "Inactive",
editorType: 'bool',
// columnKey: "SurveyorID",
// editorType: 'combo',
// validation: true,
// required: true,
// editorOptions: {
// mode: "dropdown",
// dataSource: jsonsurveyorName,
// textKey: "Name",
// valueKey: "SurveyorID"
columnKey: "Surveyor",
validation: true,
required: true,
editorOptions: {
mode: "dropdown",
textKey: "Name",
valueKey: "Name"
columnKey: "Company",
validation: true,
required: true,
editorOptions: {
mode: "dropdown",
dataSource: jsonNominatingCompanies,
textKey: "Name",
valueKey: "Name"
// columnKey: "NominatingCompanyID",
// required: true,
// editorOptions: {
// dataSource: jsonNominatingCompanies,
// textKey: "Name",
// valueKey: "NominatingCompanyID"
columnKey: "Text",
editorType: 'string',
validation: true,
editorOptions: { required: true }
else {
var surveyorCombo = ui.owner.editorForKey("Surveyor").data("igCombo");
var surveyorID = surveyorCombo.options.dataSource[surveyorCombo.selectedIndex()]["SurveyorID"];
var companyCombo = ui.owner.editorForKey("Company").data("igCombo");
var companyID = companyCombo.options.dataSource[companyCombo.selectedIndex()]["NominatingCompanyID"];
var row = ui.values;
row["SurveyorID"] = surveyorID;
row["NominatingCompanyID"] = companyID;
on executing of   SaveUnSaveGridOnConfirmation('fromPickList', this); function getting hanged and below error is coming
if(this.options.dataSourceUrl||this.dataSource.type()==="remoteUrl"
Detaill of   function SaveUnSaveGridOnConfirmation(calledFromMethodName, currentPickListObject)  is as follows
function SaveUnSaveGridOnConfirmation(calledFromMethodName, currentPickListObject) {
EndEditChangesOnSaveAndReload();
if (($("#gridPickList").data("igGrid") != null && HasPendingTransactions($("#gridPickList"))) || ($("#gridDependentPickList").data("igGrid") != undefined && HasPendingTransactions($("#gridDependentPickList")))) {
$("#dialogYesNoCancel>p>label").text("There are unsaved changes on this screen. Do you want to save them first before closing?");
$("#dialogYesNoCancel").dialog({
resizable: false,
height: 140,
modal: true,
buttons: {
"Yes": function () {
if (HasPendingTransactions($("#gridPickList")) == true) {
$("#gridPickList").igGrid("saveChanges");
isPicklistModified = true;
RefreshParentGrid();
alert("changes have been saved");
$(this).dialog("close");
alert("ok2");
if ($("#gridDependentPickList").data("igGrid") != undefined) {
if (HasPendingTransactions($("#gridDependentPickList")) == true) {
$("#gridDependentPickList").igGrid("saveChanges");
RefreshDependentGrid();
if (calledFromMethodName == 'fromChkShowInactiveRows') {
alert("ok3");
if ($("#chkShowInactiveRows").is(':checked')) {
$('#chkShowInactiveRows').prop('checked', false);
} else {
$('#chkShowInactiveRows').prop('checked', true);
doCheckUnCheckActivity();
alert("ok4");
if (calledFromMethodName == 'fromPickList') {
alert("ok5");
//if ($("#chkShowInactiveRows").is(':checked')) {
// $('#chkShowInactiveRows').prop('checked', true);
//} else {
// $('#chkShowInactiveRows').prop('checked', false);
//doCheckUnCheckActivity();
doPickListActivity(currentPickListObject);
alert("ok6");
if (calledFromMethodName == 'frombtnClosePick') {
alert("ok7");
//} else {
btnCloseActivity();
alert("ok8");
//ReloadNominationForm();
"NO": function () {
alert("changes have not been saved");
ReloadGrid($("#hdnGridName").val());
//if (HasPendingTransactions($("#gridPickList")) == true) {
// RollbackChangesForParentGrid();
// alert("changes have not been saved");
// $(this).dialog("close");
//if ($("#gridDependentPickList").data("igGrid") != undefined) {
// if (HasPendingTransactions($("#gridDependentPickList")) == true) {
// RollbackChangesForDependentParentGrid();
} else {
//} else {
alert("afterendofpicklis");
//} else {
btnCloseActivity();
alert("afterendofclose");
Cancel: function () {
return false;
return false;
Please let me know why executing SaveUnSaveGridOnConfirmation , a dialogbox opens and when i clicked on "Yes", getting hanged
and error is coming (if(this.options.dataSourceUrl||this.dataSource.type()==="remoteUrl" is coming null)
Early response is appreciated.
Poonam
