170
infragistics.templating.js error
I am getting java script error :Cannot read property 'replace' of undefined infragistics.templating.js  with the below template
template: "{{if ${AggregateAuthority}==true}}<label class='agg-authority-star' name='a' id='star-1' style='margin-top:-3px;' data-toggle='popover' data-container='body' data-placement='top'></label>{{else}}<label class='' name='a' id='star-1' style='margin-top:-3px;'></label>{{/if}}"
I attached the sample code
please tell me how to solve this problem.
Regards
Raghu
  • 20255
    Suggested Answer
    Hello Raghu,
    Thank you for contacting us.
    Everything seems fine with your template structure. In order to try to reproduce the issue I have created a sample for you, although I couldn't invoke it. Could you please have a look at the attached sample, I hope you will gain from it. The sample is related to our igCombo widget, not igGrid, although the approach is the same. Also can you please try to remove the 3rd party attributes that you use like data-container and data-toggle, and let me know what are the results.
    Also below you will find a couple of useful references regarding our templating engine:
    Adding a templating Engine Refereces
    Creating a conditional template containing a default statement
    TemplatingExample.zip
