960
JSON object with subobject as datasource for igGrid
I have an igGrid that I want to use a JSON object as the datasource. The object is built from a DB call in an AJAX request from a 'relationship' table and the object associated to it. The relationship table has the parent ID, the type of relationship and the child ID, with all the child details in a child table based on child ID. The data is queried as a Hibernate join between these tables based on the parent ID, so the Java object returned looks like this.
class children {
    int parentID;
    int childID;
    String type;
    Child child;
The subsequent JSON object models this list of children as an array of these 'relationships' with the child being a sub-object within each 'row', exactly how it should. My problem is that I can't get the subobject values to appear in my grid. I have it defined like this :
                { headerText: "Type",        key: "type",              dataType: "string" },
                { headerText: "Name",       key: "child.name",    dataType: "string" },
The 'type' field shows up in the grid, but the 'child.name' field does not. I can access the child data fine in javascript exactly how I'd expect, but the grid stays blank.
What am I doing wrong? Thanks in advance...
