Is there any way to know that the option multipleSelection and virtualization of the grid is set to true using JQuery.
I found the two options in http://help.infragistics.com/jQuery/2014.1
$(gridId).igGridSelection("option", "multipleSelection");
$(gridId).igGrid("option", "virtualization");
which are supposed to return a true/false value but these returns the object containing the reference of grid.
Please let me know if there is any other way to know the same or I am missing something.
Sarvesh J.
Hi Michael,
Thanks for your inputs on this. Now I am able to get the Boolean type return value with these options. I don't know where was the mistake but now it is working fine.
Hello Sarvesh J.,
Please let me know if you have any other questions or concerns about this issue and I'll be glad to help you.
Thank you for posting in our forums!
Could you please let me know what version and build of IgniteUI you are experiencing this with? And is this occurring with any specific browsers?
I have tested this with IgniteUI 2014.2.20142.1024 in IE10, Chrome and Firefox and these methods return true or false.
I have attached the sample project I used to test this. Please test this project on your PC; whether or not it works correctly may help indicate the nature of this problem.
If the project does not work correctly, this indicates either a problem possibly specific to your environment, or a difference in the javascript versions we are using.
If the project does show the product feature working correctly, this indicates a possible problem in the code of your application. It will help if you can provide a small, isolated sample application that demonstrates the behavior you are seeing.
Or, if this sample project is not an accurate demonstration of what you're trying to do, please feel free to modify it and send it back, or send a small sample project of your own if you have one.
Please let me know if I can provide any further assistance.
