I can't localize my igGrid. The code below is my partialView. Any Idea why it doesn't work ?
@using Infragistics.Web.Mvc;
@model IQueryable<Terminal>
@(Html.Infragistics().Loader().Render())
// $.ig.loader({ scriptPath: "http://cdn-na.infragistics.com/jquery/20122/latest/js/", cssPath: "http://cdn-na.infragistics.com/jquery/20122/latest/css/", resources: "igGrid.*", autoDetectLocale:true });
@( Html.Infragistics().Grid(Model) .ID("GridResearchTerminal") .Width("100%") .Height("500px") .PrimaryKey("Id") .AutoGenerateColumns(false) .AutoGenerateLayouts(false) .Columns(column => { column.For(x => x.Reference).HeaderText("Reference").Width("20%"); column.For(x => x.Brand).HeaderText("Brand").Width("20%"); column.For(x => x.Model).HeaderText("Model").Width("20%"); column.For(x => x.PhoneNumber).HeaderText("PhoneNumber").Width("40%"); }) .Features(features => { features.Selection() .Mode(SelectionMode.Row) .MultipleSelection(false) .AddClientEvent("rowSelectionChanged", "onRowTerminalSelectionChanged"); features.Sorting().Type(OpType.Remote); features.Paging().Type(OpType.Remote); features.Filtering() .Type(OpType.Remote) .Mode(FilterMode.Advanced) .ShowNullConditions(true) .ShowEmptyConditions(true); features.ColumnMoving(); features.Resizing(); }) .LoadOnDemand(true) .AutofitLastColumn(true) .MergeUnboundColumns(true) .DataSourceUrl(Url.Action("GetTerminal")) .Render())
Ok Martin thank you. You can close the thread.
Hello Nicolas,
The reason is that they are excluding each other. If you're using the Infragistics Loader then you should not reference the infragistics.core.js, infragistics.dv.js and infragistics.lob.js and vice versa.
Best regards,Martin PavlovInfragistics, Inc.
Now my question is why if I add infragistics.core.js, infragistics.dv.js and infragistics.lob.js the loader doesn't work ?
Hi Martin,
I'm sorry to answer late. Indeed i looked one of your old posts that's why I mixed Razor and JavaScript Loader, my mistake. Now i'm using just the razor. And I used 3 js files (infragistics.core.js, infragistics.dv.js, infragistics.lob.js) that created the conflict with infragistics.loader.js. So i deleted them and now it works.
I tested the loader with autoDetectLocale option set to true and it works on my side. Note that the loader uses the navigator.language of the browser and in order to work as expected the browser navigator.language should be "fr" in your case.
I'm attaching my sample for your reference.
I'm wondering why are you mixing Razor initialized loader and JavaScript loader? Maybe that's the reason for your problem.
The other cause can be the language settings of your browser. The French should be on top of the list. For example on Chrome you can open the language settings using the following Url: chrome://settings/languages#language
Hope this helps,
Martin Pavlov Infragistics, Inc.
