1810
Need help on iggrid column format
Hi
I am using iggrid (jquery) and facing one problem i am binding grid with number column with format as currency, by default its shows two decimal places value for that column is there any way to configure that so i can make it to display as much decimal places value as i want.
we can try column for-matter but as i know column for-matter will make that value to string and it will create problem in filter and sorting since data will work like string (make me correct if i am wrong) so i can't use formatter
so is there any way to configure decimal places on currency format
  • 11095
    Hello Prakash,
    I'm just following up to see if you need any further assistance with this issue. If so please let me know.
  • 11095
    Hello Prakash,
    Thank you for contacting Infragistics Developer Support!
    Actually the format or the formatter function are used only for data display.
    If your column value is configured as decimal, it will stay decimal. The grid filters by the dataSource values.
    So using formatter is the correct approach.
    You can review the following sample. Notice how all values in the price coulmn are shown as some value.
    However if enter 4.215546 you will still get the correct record and if you enter some value you will get nothing.
    If you have any additional questions please let me know.
