I want to use a border layout that uses 100% width and 100% height of the window. As stated in the documentation of the reflow method, one should use percent sizes. So I grabbed your sample code and replaced the pixel height (300px) by percent height (100%).
With this settings the border layout does not work at all. The footer is not displayed at the bottom. I have to scroll to the footer. What am I doing wrong? I have added the code as an attachment. I am using IE10.
I additionally tried to set width/height in the options, but with no result.
Thanks in advance for your help.
Michael
Hi Michael,
Thank you for the update.
The sample in your previous post doesn't show with a height of 100% because the height of the layoutManager isn't set to 100%. The initialization logic for the layoutManager should like like:
$('#layout').igLayoutManager({ layoutMode: "flow", //you have to set the height of the layout manager height: "100%", items: [ { width: "100%", height: "100%" } ] }); });
Also, I have attached my modified version of the two sample's you've attached to this thread.
Please let me know if you have any questions regarding this matter.
Hi Jose,
thanks for the reply. But it still seems not to work. I have attached an example. I have added the html,body { } styles as you have suggested, but the resize still not work properly.
Kind Regards
Thank you for posting on our forums.
Please note that whenever you utilize a percent width or height for an element, the size will be relative to the element's parent. To ensure the div element consumes 100% of the width and height of the visible area of the browser, please use the following CSS snippet: <style type="text/css"> html, body { height: 100%; margin: 0px; }</style>
Also, please provide me with more details about what you did to set the width/height in the options. Are you referring to the igLayoutManager's options? If so, please not that the igLayoutManager doesn't have a setter option for height and width. To learn more about these options, please review the API docs linked below:ui.igLayoutManager height only has a getter:http://help.infragistics.com/jQuery/2014.1/ui.iglayoutmanager#options:height ui.igLayoutmanager width only has a getter:http://help.infragistics.com/jQuery/2014.1/ui.iglayoutmanager#options:width Please let me know if you have any questions regarding this matter.
