I tried more in insert hyper link in ignite grid . please help out . I need 1 column should be hyperlink (run time value) with passing parameter.
Issue : Href value and Name should dynamically bind Example ContractName in href and contract type to passing variable.
var data1 = [ { "StartDate": "07/01/14", "EndDate": "07/01/16", "ContractName": "Data Monitoring Committee", "ContractType": "DMC Contract", "Brand": "", "ContractStatus": "Pending" }
{ "StartDate": "08/01/14", "EndDate": "08/01/16", "ContractName": "General Consulting", "ContractType": "General Consulting Contract", "Brand": "", "ContractStatus": "Signed" },
$("#grid1").igGrid({ autoGenerateColumns: false, renderCheckboxes: true, width: "100%", columns: [ { headerText: "Start Date", key: "StartDate", dataType: "date", width: "15%", format: "dd/MM/yy" }, { headerText: "End Date", key: "EndDate", dataType: "date", width: "20%" }, { headerText: "Contract Name", key: "ContractName", dataType: "string", width: "20%" }, { headerText: "Contract Type", key: "ContractType", dataType: "string", width: "15%", unbound: true, template: "<a href="runtime value" > ${ContractType} </a>" }, { headerText: "Brand", key: "Brand", dataType: "string", width: "15%"}, { headerText: "Contract Status", key: "ContractStatus", dataType: "string", width: "15%" } ], primaryKey: "ContractType", dataSource: data1, responseDataKey: "results", features: [ { name: "Responsive", enableVerticalRendering: false, columnSettings: [ { columnKey: "EmployeeID", classes: "ui-hidden-phone" }, { columnKey: "PostalCode", classes: "ui-hidden-phone" } ], responsiveModes: { customPhone: { minWidth: 0, maxWidth: 600 }, // alternative mode customAlt: { minWidth: 601, maxWidth: Number.MAX_VALUE } } }, { name: "Sorting", type: "local" } ] });
Hello Kannan,
I am following up to see if the information provided has resolved this matter.
Please let me know if I may be of further assistance with this matter.
If you want to have a column that is a link you will want to fill the href field with the location the link should take you. For example:
template: "<a href='www.google.com'>${ProductNumber}</a>"
format: "<a href='www.google.com'>{0}</a>"
http://es.infragistics.com/community/forums/p/88405/438959.aspx#438959
Please let me know if you have any further questions concerning this matter.
