2732
Hierarchical column synchronization
I'm currently converting a windows forms application to the web. The screen I have a problem with contains a hierarchical grid. Each level contains the same columns (14 total) with most columns hidden by default. I want the column chooser functionalitity, column moving and column resizing functionality to synchronize between each level/band.
In WinForms grid I solved it by subscribing to the "AfterColPosChanged" event.
private void grdTimeInfos_AfterColPosChanged(object sender, AfterColPosChangedEventArgs e)
//create and get the Grids Event manager.
GridEventManager gridEventManager = grdTimeInfos.Base.EventManager;
//We need to turn off the AfterColPosChanged event so it wont be called over and over agin when we
//change the position of the bands in the subsequent bands.
gridEventManager.SetEnabled(GridEventIds.AfterColPosChanged, false);
//call the Synchronize method
SynchronizeColumns(e.ColumnHeaders, e.PosChanged);
//Turn the event back on so it will work next time
gridEventManager.SetEnabled(GridEventIds.AfterColPosChanged, true);
The synchronizecolumns method handles the 3 possible change events: move, swap and visibliltiy change.
private void SynchronizeColumns(ColumnHeader[] columHeaders, PosChanged positionChanged)
switch (positionChanged)
case PosChanged.Moved:
//iterate through the Bands Collection
foreach (UltraGridBand band in grdTimeInfos.Base.DisplayLayout.Bands)
//make sure that we don't move the same band column that we moved
if (band.Key != columHeaders[0].Band.Key)
//for moving, we only need to worry about visiblePostions. So, all we do is
//set the visible position of the grid column in the next band which
//has the same key as ColumnHeader[0]
band.Columns[columHeaders[0].Column.Key].Header.VisiblePosition = columHeaders[0].VisiblePosition;
break;
case PosChanged.Swapped:
//iterate throug the Bands Collection
//make sure that we don't swap the same band columns that we just swapped
//use the swap method on the colum to swap the two columns that we get from the
//olumnHeader array.
band.Columns[columHeaders[1].Column.Key].Swap(band.Columns[columHeaders[0].Column.Key]);
break;
case PosChanged.HiddenStateChanged:
band.Columns[columHeaders[0].Column.Key].Hidden = columHeaders[0].Column.Hidden;
break;
Now I want to implement the same functionality in the web interface.
Has something like this be done already, or can you point me to the correct event(s) I need to use to accomplish this?
A challenge!
Kind regards,
Michael
