1145
Hidden Column Access Bar difficult to select
Hi
The attached screen print shows four screen shots, where I am moving the cursor very slowly to the right, (click on image to see full picture).
It is extremely difficult to select the "Hidden Column(s)" command.
Starting from the left hand side, the command will be "click to sort column".
Moving the cursor very slightly reveals "Hidden Column(s)"
Moving the cursor very slightly (again) loses "Hidden Column(s)" to be replaced with the resize cursor and the "click to sort column",
Continuing to move the cursor to the end, changes the cursor back to the selection cursor but the command remains as "click to sort column".
Any advice on
  • only display "Hidden Column(s)" or increase its active area
  • prevent the cursor changing to resize.
Regards
Aidan
Parents Reply Children
No Data
