Fiddle - http://fiddle.jshell.net/eSMWt/
1) I have two separate grid one is HierarchicalGrid and other is IgGird on web page.
2) When HierarchicalGrid is expanded it include columns of other grid.
Seems like bug to me.
-Manish
Hello Manish Dalal,
The fix for this issue 172064 "Columns are added unexpectedly" has been addressed in service release versions 2013.1, 2013.2, 2014.1. To take advantage of this fix, please download the latest service release using the instructions found here: http://community.infragistics.com/forums/t/29398.aspx.
Hi Manish Dalal,
I have investigated the issue regarding Columns of second igHGrid appear as child of first igHGrid. I have asked our Product Development to examine this further. To ensure that it will receive attention, I have logged this behavior in our internal tracking system with a Development ID of 172064. The next step will be for a developer to review my investigation and confirm my findings or to offer a fix, or other resolution.
I will be sure to update this forum thread once I receive more information about the results of their investigation.
Ok it works with 1.8.18 version but i still think this i an issue with ignite ui. As Ignite UI support jquery UI 1.10.3
http://code.jquery.com/ui/1.10.3/jquery-ui.min.js
Its igrniteUI responsibility to write API which works with supported version.
Hello Manish,
Thank you for your patience.
I have isolated this issue to be cause by jQuery. I was unable to reproduce this behavior using the following scripts:
<script type="text/javascript" src="http://code.jquery.com/jquery-1.7.2.min.js"></script> <script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/jqueryui/1.8.18/jquery-ui.min.js"></script> <script src="http://modernizr.com/downloads/modernizr-latest.js"></script>
Can you confirm this in your environment? Depending on the outcome, you may need to log a bug with jQuery.
I am looking forward to hearing from you.
Thanks!
So I'm reopening my case again. (CAS-137183-M8W1R2)
