495
Radiabutton list in igHirerachicalgrid
Hi, How can introduce the radio button list in igHirerachicalgrid.
I did achieve it by template column but they do not work as all the buttons in the rows have same name and id. So is there a way to do so that they have different group name for each row and id's?
My sample code:
eSignaturegroup.Group.Add(new GridColumn() { Rowspan=2 , HeaderText = "In Person",Key = "eSign",DataType = "bool",Width = "10%",FormatterFunction = GetESign("InPerson") });
eSignaturegroup.Group.Add(new GridColumn() { HeaderText = "Remote",Key = "eSign",DataType = "bool",Width = "10%",FormatterFunction = GetESign("Remote") });
private  string GetESign(string eSign)
           var sb = new StringBuilder();
           sb.Append(" function(obj){");
          if (eSign.Equals("InPerson"))
               sb.Append(" if (obj == 0 ){return ' <ul class=radio-group> <li><input id=InPerson_" + i + " name=esign_" + i + " type=radio checked=checked /> <label for=InPerson_" + i + "><span><span></span></span></label></li></ul>';}");
               sb.Append(" if (obj == 1 ){return '<ul class=radio-group> <li><input id=InPerson_" + i + " name=esign_" + i + " type=radio   /><label for=InPerson_" + i + "><span><span></span></span></label></li></ul>';}");
           else if (eSign.Equals("Remote"))
               sb.Append(" if  (obj == 1 ){ return '<ul class=radio-group> <li><input id=Remote_" + i + "  name=esign_" + i + "  type=radio checked=checked /><label for=Remote_" + i + "><span><span></span></span></label></li></ul>';} ");
               sb.Append(" if (obj == 0 ){return '<ul class=radio-group> <li><input id=Remote_" + i + "  name=esign_" + i + " type=radio  /><label for=Remote_" + i + "><span><span></span></span></label></li></ul>';}");
         sb.Append("} ");
           return sb.ToString();
is there a way where I can send the row index so that it can work. Also how can I send the row index in this context?
Your help is much appreciated.
