365
igGrid doesn't reflect saved changes
I am using the igGrid with a web API that saves changes similar to the way an MVC controller does. I have confirmed that the data from the igGrid is sent to the web API correctly (it is actually saved to the database). The only remaining problem is that the grid still shows deleted rows with a strikethrough and added/modified rows in italics.
Here's the JavaScript for the igGrid:
                $("#grid1").igGrid({
                    dataSource: "/api/processes",
                    updateUrl: "/api/processes/save",
                    primaryKey: "processID",
                    autoGenerateColumns: false,
                    height: "350px",
                    width: "800px",
                    columns: [
                            { headerText: "Process ID", key: "processID", dataType: "number" },
                            { headerText: "Name", key: "name", dataType: "string" },
                    features: [
                                editMode: 'cell',
                                columnSettings: [{
                                    columnKey: 'processID',
                                    readOnly: true
And here is the response I'm returning from my web API:
JsonResult result = new JsonResult();
Dictionary<string, bool> response = new Dictionary<string, bool>();
response.Add("Success", true);
result.Data = response;
return result;
The result translates to this JSON: {"data":{"Success":true},"jsonRequestBehavior":"DenyGet"}
I also tried returning {"Success":true}
My question is: What should I return from the web API to tell the igGrid that data was saved successfully so it will make deleted rows disappear and turn off italics on added and modified rows?
Thanks in advance.
