2334
Angular directive for igRadialGuage
Edit: Here is the jsfiddle - http://jsfiddle.net/aschaeffer/s6REN/
I am trying to write a directive for the igRadialGuage control. Firstly, I aim to do a most basic example. The source is pasted below.
Using the below directive I get the error "TypeError: Object [object Object] has no method 'igRadialGuage'"
Are there any samples of how to build a directive for any of the charts/guages?
app.directive("radialguage", function() {
	console.log("rg");
  return {
    restrict: "E",        // directive is an Element (not Attribute)
    scope: {              // set up directive's isolated scope
      value: "@",        // amount var passed by value
      max: "@",        // amount var passed by value
      height: "@"
    template:             // replacement HTML (can use our scope vars here)
    replace: true,        // replace original markup with template
    transclude: false,    // do not copy original HTML content
    link: function (scope, element, attrs, controller) {
    	console.log(element);
    	console.log(scope.height, scope.max, scope.value);
    	element.igRadialGuage("option", "height", scope.height);
    	element.igRadialGuage("option", "width", "100%");
    	element.igRadialGuage("option", "maximumValue", scope.max);
    	element.igRadialGuage("option", "value", scope.value);
    	scope.$watch("value", function(newValue, oldValue, srcScope) {
    		element.igRadialGuage("option", "value", newValue);
  • 2334
    Verified Answer
    I figured out the issue. Apparently you have to initiate the gauge using the following function rather than using element.igRadialGauge. The jsfiddle is update to show the working example. http://jsfiddle.net/aschaeffer/s6REN/
        	$("#radialGauge").igRadialGauge({
                height: scope.height,
                width: "100%",
                maximumValue: scope.max,
                value: scope.value
