I have an infragistics Ignite Grid, with horizontal and vertical scroll bar. All is fine, except when viewing the page from a Panasonic CF31 with Firefox 24. In this case the vertical scroll bar disappears. I can put the grid inside a div and using overflow can have scrollbars that way, but its not desrireable because the header 'scrolls away'.
Anyone have an idea how I can debug this?
Device resolution Div Scroll Infragistics Scroll
Desktop 1024x768 works works
CF31 1024x768 works no vertical scroll bar
CF30* 1024x768 works works
<div id="GridWrapper" data-bind="visible:EventDataRetrieved" >
<table id="eventsGrid" data-bind="igGrid: {dataSource: eventData, responseDataKey: 'Records', autoGenerateColumns: false, autoGenerateLayouts: false, height:'350', width:'950', renderCheckboxes: true,autoCommit:true,primaryKey:'row_id',
features:
featureChooserText:'features',
groupByAreaVisibility:'top',
modalDialogHeight:200
mode: 'row',
multipleSelection: true,
rowSelectionChanged: onRowSelected
type: 'local'
tooltipShowing : function(evt, args)
columnSettings: [
{ columnKey: 'has_footprint', allowTooltips: true },
{ columnKey: 'entry_tstmp', allowTooltips: true }
visibility: 'always',
showDelay: 1000,
hideDelay: 500
{ name: 'Updating', enableAddRow: false, enableDeleteRow: false, editMode: 'none',
columnKey: 'footprint_avail',
editorOptions: { readOnly: 'true' }
columnKey: 'entry_tstmp',editorOptions: { readOnly: 'true' }
columnKey: 'group_name', editorOptions: { readOnly: 'true' }
columnKey: 'sub_name',editorOptions: { readOnly: 'true' }
columnKey: 'loc_name', editorOptions: { readOnly: 'true' }
columnKey: 'ev_cfg_desc', editorOptions: { readOnly: 'true' }
columnKey: 'manu_name',editorOptions: { readOnly: 'true' }
columnKey: 'model_num', editorOptions: { readOnly: 'true' }
columnKey: 'mech_val', editorOptions: { readOnly: 'true' }
columnKey: 'ctr_voltage_val',editorOptions: { readOnly: 'true' }
columnKey: 'event_note_count', editorOptions: { readOnly: 'true' }
columns: [
{key: 'entry_tstmp', headerText: 'Time Stamp', width: 120, dataType: 'date', format: 'M/d/yyyy HH:mm:ss tt' },
{key: 'group_name', headerText: 'Group Name', width: 60, dataType: 'string'},
{key: 'sub_name', headerText: 'Sub Name', width: 100, dataType: 'string'},
{key: 'equipment', headerText: 'Equipment', width: 100, dataType: 'string'},
{key: 'loc_name', headerText: 'Breaker', width: 200, dataType: 'string'},
{key: 'ev_cfg_desc', headerText: 'Event', width: 50, dataType: 'string'},
{key: 'manu_name', headerText: 'Mfg', width: 50, dataType: 'string'},
{key: 'model_num', headerText: 'Model', width: 100, dataType: 'string'},
{key: 'mech_val', headerText: 'Mech', width: 100, dataType: 'string'},
{key: 'mech_op_val', headerText: 'Mech Op', width: 100, dataType: 'string'},
{key: 'ctr_voltage_val', headerText: 'Battery', width: 100, dataType: 'string'},
{key: 'event_comments', headerText: 'Event Notes', width: 100, dataType: 'string',
template: '<input type=\'button\' value=\'${event_comments}\' data-id=\'${ev_hdr_id}\' class=\'cmdbtngrid\' onclick=\'model.eventNote(this)\'/>'},
{key: 'asset_comments', headerText: 'Breaker Notes', width: 100, dataType: 'string',
template: '<input type=\'button\' value=\'${asset_comments}\' data-id=\'${equipment}\' class=\'cmdbtngrid\' onclick=\'model.assetNote(this)\'/>'},
{key: 'footprint_avail', headerText: 'Has Footprint', width: 100, dataType: 'bool'},
{key: 'closes_wo', headerText: 'Closes Work Order', width: 100, dataType: 'bool'},
{key: 'sys_voltage_val', headerText: 'Sys kV', width: 50, dataType: 'number'},
{key: 'ev_hdr_id', headerText: 'Event Hdr Id', width: 80, dataType: 'number'},
{key: 'allow_change_wo', headerText: 'allow_change_wo', width: 80, dataType: 'bool', hidden:true},
{key: 'row_id', headerText: 'row', width: 80, dataType: 'number', hidden:true},
{key: 'device_id', headerText: 'Device', width: 80, dataType: 'string'},
{key: 'cfg_id', headerText: 'Cfg', width: 80, dataType: 'number'},
{key: 'trigr_ev_num', headerText: 'trigr_ev_num', width: 80, dataType: 'number', hidden:true},
{key: 'system_status', headerText: 'Status', width: 80, dataType: 'string'},
{key: 'wo_complete_val', headerText: 'wo_complete_val', width: 80, dataType: 'number', hidden:true},
</table>
</div>
Please feel free to contact me if you are still experiencing any issues with this scenario.
Hello jsspooner_mso,
Thank you for the sample !
I had to reduce the number of rows to one third as in my tests Firefox was displaying a long running script exception. The issue in this case seems to be relate to individual browser speed - especially in terms of rendering the template contents (note that in this case that is 2000 buttons). IE11 appears to be scaling worse than Firefox in rendering large number of elements but for 1/3 of the data the differences are relatively small. I would suggest considering to use paging or virtualization with such a large data source in order to reduce the number of rows rendered at a time - these features can have dramatic effects on performance.
Hope this helps. Please do not hesitate to contact me with any questions.
Attached is a sample file. (I was involved in deploying something) It shows that with the template buttons in my grid , 1000 rows of data, IE11 is painfully slow, and Firefox tho faster is still fairly slow.
Without the template buttons Firefox and IE are similar in speed. My plan is provide the functionality of the buttons in another matter that is slightly less convenient, but the customer can live with.
As a bonus error on my part , if hit the reapply button to update the data I get a script timeout. I may be doing something wrong, this is my first exposure to v2.
Hello jspooner_mso,
So far I am still unable to replicate the performance issue described. Is it possible to share a working sample illustrating the scenario in order to allow me to examine this further ?
Please do not hesitate to contact me with any updates or questions.
Thank you for your reply !
I am currently researching into the performance implications of templating in the igGrid under IE11 and will keep you posted of my findings.
