I am using igGrid with paging and would like to disable the user input in the page picker dropdown. Preferably I would like the dropdown to work as a regular dropdown and the input field itself being readonly (so that the user cannot type a page number). I have tried applying the disabled HTML attribute to the page picker input field with no luck. If this is not possible I would like to disable the page picker dropdown completely.
Thank you!
Hello Elin,
You can handle pagerRendered event for the purpose:
http://help.infragistics.com/jQuery/2013.2/ui.iggridpaging#events
By default the current page dropDown isn't readOnly so you need to set it explicitly:
features: [ { name: 'Paging', type: "local", pageSize: 10, pagerRendered: function ( evt, ui ) { var currentPageDropDown = ui.owner._curPageDD; currentPageDropDown.igEditor( "option", "readOnly", true ); currentPageDropDown.igEditor( "option", "dropDownOnReadOnly", true ); } }]
Let me know if you need further assistance.
