Hi All,
We have an igFileUpload that we use to upload CSV files using WCF REST for processing at the server, and to retrieve info back (i.e. validated data).
However, we are experiencing a problem where once we've used the file upload, it does not want to upload another file until we do a full refresh on the page.
We can select a file, but the igFileUpload just does nothing until we do a refresh, select the file again and then it goes through.
Any thoughts/ideas on what can be causing this?
Eduard Kruger.
Hi Petar,
Sorry for not getting back to you sooner, but I had other priorities.
I've figured out the problem is due to the object I use from the igFileUpload control to get the data returned from the server. I was always using the igGrid object's filesInfo array object for index 0, I did not realize all subsequent uploads increased the array size and thus each new upload had a new element. I've changed my code to always use the upper bound object in the array, and the page works 100% now.
Thanks for the feedback, regardless. You may close the issue.
Hello Eduard,
Please do not hesitate to contact me if you are still experiencing any issues with this scenario.
I would suggest examining the network activity in the developer tools after uploading a file. Are there any responses with errors ? It may also be helpful to handle theonErrorevent and check whether any errors are raised during the first upload. A small sample application would allow me to examine this matter further and in more detail.
Please do not hesitate to contact me with any updates regarding this matter.
Post Bump
