4040
Conditionnal column template
I would like to apply a template on a column of an editable hierarchical grid.
To do this I use the template property of the column and write a conditionnal template.
My template depends on other colonne so I tested it ad describe in your template engine documentation.
My problem appears when I want to test a boolean column that have the template property set. The get value in the template is not the boolean but a string containing the default checkbox template.
Is there a way to get the value instead of this string ?
I hosted a sample to show you how I did it : http://sdrv.ms/1b0JtSO.
Regards.
