Hi
I am trying to freeze Header fields in igGrid, but not found any solution.Is there any option to freeze IgGird Header?
Thanks Petko Zhekov
Now it's working fine for me.
I am Using iggrid with check box ,Now i need to add shortcut Key for Check box.Is There any option to add shortcut keys to iggrid control.
Hi Kiran,
Thank you for posting in our forums. What do you mean by “freeze Header fields”? The igGrid has an option called fixedHeaders which is true by default. It allows the headers to stay on top of the grid even if you scroll the grid vertically.
I’m looking forward to your reply!
Kind regards, Petko Zhekov Software Engineer
