2745
igGridColumnFixing /w others features enabled
When paired with igGridHiding, the API throws an error as the documentation says it is currently unsupported.  Are there any future plans to support both features simultaneously?
  • 2745
    Verified Answer
    I found the breaking changes section that says there are future plans to support it.
    http://help.infragistics.com/Help/Doc/jQuery/2013.2/CLR4.0/html/igGrid_Known_Issues.html
  • 265
    do you have a feature matrix of which feature is supported with which feature? Can you point me to some specific documentation about the limitations of Ignite UI?
    While evaluating Ignite UI, I received the "not supported" message with the combination of features myself.
    I would like to have an overview before making a purchase decision.
    The problem is that all Ignite UI demos show each feature by itself, so there is no way to see what might work, what should work, what will work sometime in the future and what will never work.
    Best regards,
    Peter
