40
Iggrid rowedittemplate dropdown control does not have an id
I have an igGrid that has editmode set to rowedittemplate.  I have multiple columns in the grid, but 2 of them have editorOptions 'editortype: text' and 'button: dropdown'.  These 2 columns are interdependent on each other, so I need to catch the valuechanged events for either to be sure the other column has the correct value.  However, I can't get the id of the either column's control.  If I set the grid's editmode to row the id show's up, and I can do what I need.  But I'd really like to use the rowedittemplate.
eg
$("#paycodegrid").igGrid({
 columns: [
                    { headerText: "Name", key: "name", dataType: "string", width: "150px" },
                    { headerText: "Description", key: "description", dataType: "string", width: "400px" },
                    { headerText: "Active", key: "active", dataType: "bool", width: "100px" },
                    { headerText: "Worked/Non-Worked", key: "workedString", dataType: "string", width: "200px" },
                    { headerText: "Hours/Amount", key: "isAmountString", dataType: "string", width: "150px" },
                    { headerText: "Hour Type", key: "hourTypeString", dataType: "string", width: "150px" },
                    { headerText: "ID", key: "id", dataType: "number", width: "5px" }
                        editMode: "rowedittemplate",
                        columnSettings: [
                                columnKey: "isAmountString",
                                editorType: "text",
                                editorOptions: {
                                    button: "dropdown",
                                    listItems: isAmountValues,
                                    dropDownOnFocus: true,
                                    dropDownOnReadOnly: true,
                                    listSelected: function (evt, ui) {
                                        debugger;
                                        if (ui.item == "Amount")
                                            $("#hourTypesCombo").igTextEditor("selectedListIndex", 3);
                                    //                                    valueChanged: function (evt, ui) {
                                    //                                        debugger;
                                columnKey: "hourTypeString",
                                editorType: "text",
                                editorOptions: {
                                    button: "dropdown",
                                    listAutoComplete: true,
                                    listItems: hourTypeValues,
                                    listDropDownAsChild: true,
                                        debugger;
                                        if (ui.value != "None")
                                            $("#isAmountCombo").igCombo("selectedIndex", 1);
The isAmountString and hourTypeString columns are interrelated.  So when the amount column changes I need to set the hour type drop-down to a certain value, and vice versa.
I need to access $("#isAmountCombo") and $("$hourTypesCombo"), but they come up empty.
Is there a trick to get the id of these controls in rowedittemplate mode?
Pete
  • 2355
    Hi Pete,
    I have investigated your issue and I have logged this behavior in our internal tracking system with a Development ID of 159202. The next step will be for a developer to review my investigation and confirm my findings or to offer a fix, or other resolution. I will create a private case and update you with any new information after the review in that case.
    For now I can offer you a temporary workaround. I used a jQuery selector instead of an ID to select the other editor and then I called its API method. I have attached a sample page that demonstrates the workaround.
    Please let me know if you need more information.
    Kind regards,
    Petko Zhekov
    Software Engineer
    sample-RETeditors.zip
