Hello Infragistics-Team,
i want to put multiple DataCharts on my Webpage. in following topic i found the solution if i want to do directly inside the View: http://es.infragistics.com/community/forums/t/69946.aspxYou told him, that he need to use different IDs for the charts. How can i do this in JQuery? Is there anyway to give the Chart an ID in JQuery? In the Doumentation i found nothing.
Thank you for help
Sincerly
André
Hello All,
This issue with the documentation is scheduled to be updated in the upcoming documentation releases. For the time being please take in consideration, that both Get and Set require “option” to be passed.
// Get
var series = $(".selector").igDataChart("option", "series");
var
series[0];
// Set
$(".selector").igDataChart("option", "series",
name:
"series1",
dataSource: data1,
title: "Price Series 1",
title:
"Price Series 1",
type: "column",
type:
"column",
xAxis: "xAxis",
xAxis:
"xAxis",
yAxis: "yAxis",
yAxis:
"yAxis",
valueMemberPath: "Item1"
valueMemberPath:
"Item1"
"series2",
dataSource: data2,
title: "Price Series 2",
"Price Series 2",
valueMemberPath: "Item2"
"Item2"
Thank you for posting in the community!
Hello Andre, Thank you for your feedback and for sharing this with us. We believe that the other community members could benefit from such threads.
Hi,it is on this page: http://help.infragistics.com/jQuery/2012.1/ui.igdatachartif you choose the Tab "Options" and scroll down to series and open it then you can read following code:
".selector"
).igDataChart(
"series"
"series1"
"Price Series 1"
"column"
"xAxis"
"yAxis"
"series2"
"Price Series 2"
"option", "series"
Hello Andre,
I am glad that you successfully implemented this functionality for your application. Thank you for sharing it with the community.
Could you please specify the location of $("selector").igDataChrat(series, [{...}]) piece of code in the API documentation, as I have believe only $("selector").igDataChrat("option", series, [{...}]) is available and at this location under options/series: http://help.staging.infragistics.local/jQuery/2013.2/ui.igDataChart
Dear Infragistic-Team,thank you for trying to help me. After a hard fight with your Online API and many different more or less successful ways to try to get my problem solved, i finally done it.
The way to get multiple series in one chart and multiple charts in one with using JQuery and AJAX is not really as simple as it is with the MVC-Helper directly in the View.Here is the JQuery-Code:
function getChart() { $.ajax({ url: actionURLs.JSON_IGChart.toString(), traditional: true, /* I M P O R T A N T */ datatype: 'json', type: "post", success: function (result) { for (var i = 0; i < result.ChartData.length; i++) { for (var j = 0; j < result.ChartData[i].DataSeries.length; j++) { if ($("#chart" + i).length == 0) { $("<div></div>").attr("id", "chart" + i).appendTo($("#igContent")); } $("#chart" + i).igDataChart({ width: "500px", height: "500px", dataSource: result.ChartData[i].DataSeries[j].DataPoints, dataSourceType: 'json', axes: [ { type: "numericY", name: "yAxis" }, { dataSource: result.ChartData[0].DataSeries[0].DataPoints, type:"categoryY", name: "Right", label: "Label", labelLocation:"outsideRight" } ] }) bindChart(result.ChartData[i].DataSeries[j], i, j); } var series = $("#chart" + i).igDataChart("option", "series"); console.log(series); } }, error: function (xhr, ajaxOptions, thrownError) { alert("Chart konnte nicht geladen werden"); } }); } function bindChart(data, index, serNr) { //console.log(data.DataPoints); if (data.ID == "failSerie") { $("#chart" + index).igDataChart("option", "axes", [ { dataSource: data.DataPoints, type: "numericX", name: "xAxis" + serNr, labelTextColor: data.Color, labelVisibility: "collapsed" } ]) $("#chart" + index).igDataChart("option", "series", [ { dataSource: data.DataPoints, type: "scatter", name: data.ID, title: data.Name, xAxis: "xAxis" + serNr, yAxis: "yAxis", xMemberPath: "Value", yMemberPath: "Value", markerType: "triangle", brush: data.Color } ]) } else { $("#chart" + index).igDataChart("option", "axes", [ { dataSource: data.DataPoints, type: "categoryX", name: "xAxis" + serNr, label: "Label", labelTextColor: data.Color } ]) $("#chart" + index).igDataChart("option", "series", [ { dataSource: data.DataPoints, type: "line", name: data.ID, title: data.Name, xAxis: "xAxis" + serNr, yAxis: "yAxis", valueMemberPath: "Value", markerType: "circle", brush: data.Color } ] ) } }Finding this solution wasn't really easy last but not least because of wrong information in the Onlie-DocumentationSo the command of setting a series is:$("selector").igDataChrat("option", series, [{...}])but in the online documentation is written to use this command:
$("selector").igDataChrat(series, [{...}])with this command nothing happens.It is my advice to you, to check you Online-API and Online-Documentations. maybe there are more mistakes.SincerlyAndré
