I am trying to create an empty grid on the mvc and then fill it using the web service response on the client side. This is for a dynamic page so the grid data can differ depending on the page it is on. I tried to do this using a List<object> list but I think it absolutely needs the column names. Is there a way to do this without using a dummy list? If I do use a dummy list and then try to update the data source I get this error: "could not find property length".
I can propose you to set autoGenerateColumns to true. For instance you can use something like this:
$(function () {
$('#Grid1').igGrid({
dataSource: [],
autoGenerateColumns: true,
autoGenerateLayouts: false,
mergeUnboundColumns: false,
responseDataKey: 'value',
generateCompactJSONResponse: false,
enableUTCDates: true,
columns: [],
primaryKey: 'CustomerID',
height: '500px',
rest: false,
odata: true,
localSchemaTransform: false
And you can dynamically populate dataSource.
If your case is more specific and you need more information please send us code sample or just a snipped and we will be glad to help you.
Miro
Hi Miro,
I am trying to create the grid using extension methods on the server side
HtmlHelperExtensions.Infragistics(helper)
.Grid<IList>(emptyList)
.ID("xyz")
.AutoGenerateColumns(true)
.AutoGenerateLayouts(true)
.Virtualization(true)
.VirtualizationMode(VirtualizationMode.Continuous)
.Height("650px")
.Width("700px")
.DataSource(emptyList)
.FixedHeaders(true)
.DefaultColumnWidth("100px")
.DataBind()
.Render();
Then on the client side I try to bind this grid with a different data source.
$('#xyz').igGrid({
dataSource: json,
autoGenerateColumns: false,
responseDataKey: 'Rows',
columns: json.Columns,
height: '500px'
This throws a java script error. Length is null or 0. If I try to bind to the parent control (div) then I get 2 datagrids on the page (which makes sense).
Thanks.
Ok, you have created the grid from the MVC and it is shown in the client side. So the next step is in some moment to data bind the grid. In your code I see you are re-creating the grid using javascript. I can show you a code snippet how to re-create the grid, and how to data bind it. Let's imaging you have a button and after clicking it you should databind the grid. Here is a sample:
var json = new Array();
//json.push({ "Id": 1, "UnitsInStock": "Unit 1" });
$('#databindButton').bind({
click: function () {
var $gridElement = $('#xyz);
$gridElement.igGrid('option', 'dataSource', json);
$gridElement.igGrid('dataBind');
In this case you should not change the columns definition. But in your case you try to re-create the grid. So my advice is first to destroy it and after that to re-create it(with the new options). Here it is the sample(I have not set a new records in json array but you can populate it as you want - this is just an example):
$gridElement.igGrid('destroy');
$gridElement.igGrid({
columns: [
{headerText: "Id", key: "Id", dataType: "number" , width: "100px"},
{headerText: "UnitsInStock", key: "UnitsInStock", dataType: "string" , width: "400px"}
width: '500px',
In this case you can set the data source as you want and you can set different column definition. I hope this will help you.
