Hello all,
I'm having troubles with igGrid and datasource option.
I already read this topic and it helps me to find a solution which, unfortunatelly, doesn't work at all.
This is my scenario:
The user had to press a button to add a row to a igGrid. Immediatly after the row is added, the saveChanges is called. If server logics are Ok, a Json result which contains my datasource is returned. In this case I want to bind the igGrid datasource to the returned result.
If I just write $("#grid1").igGrid('option', 'dataSource', data); data is appended to old data. I want to replace old data with new one.
Those are relevant code lines:
$('#grid1').igGrid( { virtualization: false, //dataSourceUrl: '/Richiesta/getRichiesta', updateUrl: '/Richiesta/updRichiesta', autoGenerateColumns: false, renderCheckboxes: true, autoGenerateLayouts: false, mergeUnboundColumns: false, responseDataKey: 'Records', generateCompactJSONResponse: false, enableUTCDates: true, autoCommit: false,columns: [ //{ key: 'num_rif_richiesta', dataType: 'number', headerText: 'rif', width: '4em' }, //{ key: 'num_riga', dataType: 'number', headerText: 'riga', width: '4em' }, { key: 'cod_tipo_articolo', dataType: 'string', headerText: 'Marchio', width: '4em' }, { key: 'cod_articolo', dataType: 'string', headerText: 'Codice', width: '6em' }, { key: 'chkurgente', dataType: 'bool', headerText: 'Urg', width: '3em' }, { key: 'des_riga', dataType: 'string', headerText: 'Descrizione', width: '10em' }, { key: 'num_qta', dataType: 'number', headerText: 'Qta', width: '2em', formatter: formatNumero }, { key: 'numdisponibilita', dataType: 'number', headerText: 'Disp', width: '2em', formatter: formatNumero }, { key: 'val_prezzo_unitario', dataType: 'number', headerText: 'Prezzo', width: '6em', formatter: formatValuta }, { key: 'prc_sconto', dataType: 'number', headerText: 'Sconto', width: '4em', formatter: formatPercentuale }, { key: 'prc_sconto_add', dataType: 'number', headerText: 'Sc Add', width: '4em', formatter: formatPercentuale }, { key: 'val_importo', dataType: 'number', headerText: 'Netto', width: '6em', formatter: formatValuta }, { key: 'mat_telaio', dataType: 'string', headerText: 'Telaio', width: '8em' }, { key: 'des_modello', dataType: 'string', headerText: 'Modello', width: '10em'}, { key: 'des_note', dataType: 'string', headerText: 'Note', width: 'auto'} ], dataBound: function(evt, ui) { $("#grid1").data("igGrid").dataSource._addChangesSuccessHandler(function (data, textStatus, jqXHR) {gridReBind(data);pulisciRiga();}); }, features: [ { name: "Selection", mode: "row", multipleSelection: false, rowSelectionChanging: function (ui, args) { }, rowSelectionChanged: function (ui, args) { selezionaRiga(args.row.index); } }, { name: "Updating", enableAddRow: false, editMode: "none", enableDeleteRow: false, showDoneCancelButtons: false }
], width: '100%', localSchemaTransform: false });
function gridReBind(data) {$("#grid1").igGrid("rollback");//$("#grid1").igGrid("dataSourceObject", data); $("#grid1").igGrid('option', 'dataSource', data); //$("#grid1").igGrid("dataBind");}
Thanks in advance
I forgot to write gridReBind function is still working this way (I changed grid to hierarchicalgrid)
$("#grid1").igHierarchicalGrid("rollback");
$("#grid1").igHierarchicalGrid('option', 'dataSource', data); $("#grid1").igHierarchicalGrid("dataBind"); };
Hello Tsvetelina,
thank you for your help. I finally found a navigation bug which exclude ifragistics bug.
Sorry for wasting time!
Hello Fabio.
Thank you for using our igGrid.
I read carefully your scenario and the only issue that I see is that you are setting the option dataSource
http://help.infragistics.com/jQuery/2013.2/ui.iggrid#options
instead calling the method dataSourceObject
http://help.infragistics.com/jQuery/2013.2/ui.iggrid#methods
I mean your code snippet should look like this
where data is pointing to the local JSON array of data that is get from the addChangesSuccessHandler.
Let me know if this helps.
