From our research we have found that tabbing works only in specific scenarios for ignite ui datagrid: 1. when filter is enabled - for navigatiing the filter row, 2. sorting - navigating the columns for sorting, 3. paging - navigate the paging ui (dropdowns for records/page).
Is there a way to setup the grid so that when the user tabs into it the first row is selected and then the arrow keys can be used to move between rows? This would be for a read only grid.
Hello Tammy,
I am following up to see if this matter has been resolved. If this isn’t the case please answer my questions:
What do you see when you run the sample I sent? What version of Ignite are you using? What service release are you using?
Thank you for the update. I have done some further looking into this matter and have updated my sample to enable filtering and summaries. I am unable to reproduce the issue you are seeing. When I hit tab it selected the row I tell it when the grid gets focus. I am attaching the sample. Please run the sample and let me know what you see. What version of Ignite are you using? What service release are you using?
The user can configure filters if that is what you’re asking. We’d like them to tab in be able to tab through the filter area and then tab into the actual rows.
Thank you for the update. I have a few questions concerning this matter. Do you do anything with the summary and filter behavior besides enable them? What are you setting the tabIndex to on the grid?
This doesn’t seem to work when the summary and filter is on. Then it only tabs through those sections. Is there a way to make it tab into the grid after the filter?
